Looking for Factory Ride Height Dimension..
Old Jan 29, 2013 | 03:17 PM
chefhhr's Avatar
So when I lowered my wagon back in May, stupid me didn't get the before ride height so I never really knew exactly the overall drop I accomplished. I've always guessed that it was a few inches front and back. Can someone tell me the ride height (on level ground of course) of their 2LT? Center of wheel from the ground to the bottom of the fender...
Old Jan 29, 2013 | 04:40 PM
ChevyMgr's Avatar
Use the following procedure to check the P and R dimensions.
1. Use your hands to lift the front bumper approximately 38 mm (1.59 in).
2. Remove your hands and allow the vehicle to lower.
3. Use your hands to jounce the front of the vehicle downward approximately 38 mm (1.59 in).
4. Remove your hands and allow the vehicle to rise.
5. The dimension (P) for the left and right side of the vehicle is measured from the bottom lip of the wheel opening to the ground measured at the center line of the front wheel.
6. Compare the measurement to the specification table. Refer to Trim Height Specifications .
7. If the measurement is outside of the specified range, replace the front springs. Refer to Strut, Strut Component, or Spring Replacement .
8. Use your hands to lift the Rear bumper approximately 38 mm (1.59 in).
9. Remove your hands and allow the vehicle to lower.
10. Use your hands to jounce the rear of the vehicle downward approximately 38 mm (1.59 in).
11. The dimension (R) for the left and right side of the vehicle is measured from the bottom lip of the wheel opening to the ground measured at the center line of the rear wheel.
12. Compare the measurement to the specification table. Refer to Trim Height Specifications .
Old Jan 29, 2013 | 04:47 PM
chefhhr's Avatar
Thank you much! Looks like I got a little more than I had figured...2-1/4" up front and about 2-1/2" in the rear.
Old Jan 29, 2013 | 06:32 PM
are you likin the Canucks now , chefhhr
Old Jan 29, 2013 | 08:42 PM
chefhhr's Avatar
I never disliked them. Like them even more now that I swapped the rears out for some that leveled out the wagon.
Old Jan 29, 2013 | 10:01 PM
Originally Posted by ChevyMgr
Attachment 14156
Attachment 14157
Not sure about that last measurement on the chart. 255/45/18 ?
chadlogan112
29
Apr 8, 2016 09:09 PM
LWS10
10
Jun 26, 2014 02:28 PM
Mike Fortin
13
Jun 13, 2012 02:13 PM
foxtrotraptor
Feb 18, 2012 10:40 AM
bluonyx
Jun 17, 2009 10:47 PM
