Looking to get airbags. at least in the back but would like FBSS
P
R
E
T
Y
C
O
L
E
R
S
What questions should I ask them?
I've never dealt with springs or anything so I have no idea what to ask.
Just keep the torch moving. If you let it sit in one spot, you will over temper them and that is where the break will occur. Should take no more than a few minutes per spring.
By even heating the coils the slight twist is spread over a larger area. The weight of the car will bring it down as you heat. This is a bit tricky though cuz in order to insure its even you have to leave the wheels on, and let the car settle onto blocks at your desired finished height. The easiest way would be to do this somewhere where there is a full lift or a pit.
I looked into Airride Tech they have a great kit but it was $2500.00 so I spent $114.00 on a set of Canucks, very smooth and great handling , the HHR doesn't bottom out and no danger or a bag blow out , I have had to stop and assist a few mini trucks on bags with an air line or bag issue , so I stayed away from bags.
garagebuilt
28
Feb 9, 2009 10:30 AM
