Lowering Kits - what's best?
Old Jan 19, 2020 | 10:36 AM
  #91
letterman7's Avatar
Ok, was able to put the MOOG springs in this morning before the temperature drops out. Hopefully they will settle a little bit, otherwise I'm back at stock ride height. MOOGs aren't terribly different than the stock spring, maybe 1/2 coil less. The coils aren't quite as tight in the progressive section, so maybe that plays a roll. I feel better that I have an actual spring under there though instead of a solid piece of steel..
ZZP on left, MOOG in the middle, stock on the right
Rear with MOOG springs
Old Jan 19, 2020 | 11:00 AM
  #92
Looks good , did you happen to measure before and after from the pavement to the wheel arch of the fenders?
Old Jan 19, 2020 | 11:02 AM
  #93
letterman7's Avatar
:-) No, I'm not that smart. Our driveway has a crown and isn't the most level thing anyway..
Old Jan 19, 2020 | 11:07 AM
  #94
Ok, just wanted to confirm your total drop front and rear.
what was that spring kit ZZP sent you?
Old Jan 19, 2020 | 12:57 PM
  #95
letterman7's Avatar
https://zzperformance.com/products/z...ring-springs-1
Old Jan 19, 2020 | 01:02 PM
  #96
That’s what I thought, to bad they don’t stand behind their products they sell , others have used this kit on HHR’s as per the reviews, I’ve not seen any problems like you experienced.
Old Jan 19, 2020 | 08:20 PM
  #97
Letterman- that looks much better & will improve with a little time. If you're in a hurry, throw a couple bags of mulch or something heavy in the far back end, for a while.
I generally measure from tire tops to fender lips. That way the ground underneath has little effect. But everyone has their own methods.
My springs did settle, but it took lil more than 50 miles, or so. My wheel gaps are even. The way I like it.
Old Jan 19, 2020 | 08:47 PM
  #98
letterman7's Avatar
:-) Yeah, I'm in no rush. My daily grind for the most part has me covering more than 30 miles a day, so I'm confident that they'll "settle" after a while. If it settles down another inch or so I'll be satisfied. Rolled it for a while right after I installed the springs and the ride is considerably better :-)
Old Jan 19, 2020 | 10:35 PM
  #99
Getting another inch, that would be a lot of settling. Good Luck with that.
Mine made night & day improvement on ride quality, & much better feel in the twisties.
Doc.Smith2011
May 10, 2011 12:53 AM
SD70M2
14
Mar 11, 2010 04:31 AM
deebo187
Feb 14, 2008 05:41 PM
deebo187
Feb 14, 2008 03:06 PM
deebo187
Feb 13, 2008 06:21 PM
