Need Help. Dreaded "Clunk" Already Replaced bushings AND links...
Old May 11, 2016 | 08:23 AM
HHR's have shocks in the rear, not struts.
Old May 11, 2016 | 08:26 AM
Matthew John Zeigler's Avatar
Yes, I know and I do know the difference too... but thanks for pointing that out, very helpful.
Old May 11, 2016 | 11:03 AM
I've seen some parts books call the rear shocks struts. When I saw it once I checked and they did list the correct number for shocks.
Old Jan 20, 2018 | 11:10 PM
mryuk's Avatar
Originally Posted by Oldblue
Order Moog K200792 bushing bearings, if you can't press them then have a machine shop do
It! Well worth the effort, I changed mine with an air chisel the first time , and a ball joint press the second time!
The first replacement rubber bushing is on the right with approximately 60,000 miles, that was an OEM GM bushing! Yeah!
The Moog bushing is on the left!
funny how the Moog on mine blew itself out and I also put 90 degree nipple grease endings on mine too easy access and I had to still replace mine so I'm going back to original ACDelco
Old Jan 20, 2018 | 11:34 PM
It sounds like you may be talking about the sway bar bushings, which accept zerk fittings. Did you grease them periodically?
In this thread, Oldblue is referring to the lower control arm rear bushing. I cannot recall anyone putting zerks on the control arms.
brazor06
Dec 11, 2022 07:59 AM
Cat Man HHR
18
Jun 11, 2018 09:49 PM
luisan
18
Aug 4, 2016 05:42 PM
BZERKED
Dec 28, 2012 01:25 AM
Jeff®
Oct 25, 2008 11:12 AM
