Painting Calipers
Old Feb 14, 2013 | 10:52 AM
Ron S's Avatar
Painting Calipers
What kind of paint to use? I saw some engine paint yesterday and it was rated at 500 degrees, will this work?
thanks
Ron
Old Feb 14, 2013 | 11:18 AM
badassbowtie's Avatar
Yes high heat engine paint will work.....usually cheaper than "caliper" paint and its probably the same stuff
Old Feb 14, 2013 | 11:23 AM
chefhhr's Avatar
I bought the $20 caliper kit from AutoZone and it's in dire need of touch up and I just painted them maybe 6 months ago. I used the cleaner that's supplied but I don't think I put enough coats on.
Old Feb 14, 2013 | 01:14 PM
Slide_Rite's Avatar
I've always used high temp engine paint on mine. Cost less, works better, and gives ya more color choices...IMO.
Old Feb 14, 2013 | 01:57 PM
the_shmoo's Avatar
Rustoleum, been on for two years no issues and cheap.
Old Feb 14, 2013 | 06:42 PM
Unless you are road racing, you don't need to worry about hi-temps. They only get up to about 120F under normal use.
You need to worry about rust and chemicals. A good job of prep will do wonders, and don't spill brake fluid.
Old Feb 14, 2013 | 07:07 PM
As donbrew stated, prep is the key.
Duplicolor caliper spraycan:
Old Feb 14, 2013 | 08:15 PM
VinceP's Avatar
I used a small wire brush and brake cleaner to prep my calipers. For color I used Rustoleum Industrial spray paint that I picked up from Home Depot. Covers really well. Large can (larger than reg. Rustoleum cans) was about $6. Only been a couple of weeks but I see no problems as of yet.
Old Feb 14, 2013 | 10:00 PM
I used Eastwoods' Ceramic engine paint.. Brush it on & it levels itself out like spray paint.
But looks like Glass & Good to 650* for just in case,... 1 Quart is enough to paint maybe 5 or 6 rides.. & needs no mix in catylist, so lasts on the shelf also..
jered6323
22
Oct 16, 2012 12:49 AM
Alexwsilver2010
12
Mar 15, 2012 06:39 PM
LawDog88
Mods - Exterior
28
Jun 18, 2011 08:25 AM
jas89tta
16
Sep 18, 2009 12:20 AM
c2vette
Apr 14, 2008 11:39 PM
