The Pedders look
Old Mar 20, 2010 | 09:19 AM
  #51
1Panel2NV's Avatar
Can't you adjust the length of the rear shocks? It looks like you can in the pictures. They look similar to the shocks I'm using. All you do is shorten them up until the springs have a little pressure when fully extended to keep them seated.
Oh, and I'll let you know if I have any CV problems. Mine are angled up. When I had my HHR they were level (non SS though). I started to get a weird noise after a while on my HHR, but it was the coilovers (ksport). Won't go the cheap route again haha
Old Mar 20, 2010 | 07:39 PM
  #52
bunkie's Avatar
The design of the shocks are the same. The problem I got into was the minimum length of the Pedders is 13 1/2". What is it with your stance shocks? Also I didn't notice a dampening adjustment on yours. So anyway I'm on the hunt for an adjustable shock with a min. length of 12 1/2" so I can get the stance set the way I want.As far as CV life, I've got inquiries in to GM to find out the max livable angle for their half shafts untill then we're just guessing.
Old Mar 20, 2010 | 10:09 PM
  #53
1Panel2NV's Avatar
I'm not sure what the minimum length is. I'll check the next time I have it in the air. There was still room to shorten them more though and I have it pretty low.
The Stance shocks have damping adjustment as well, just wasn't visible in that picture.
http://i121.photobucket.com/albums/o...lt/stance2.jpg
Old Apr 1, 2010 | 01:01 PM
  #54
bunkie's Avatar
Sway bar links
I got to researching rod ends and picked up these from one of my venders.They're over strong so I whittled some bars out of 6061-T6 along with a couple gr-8 studs. I probably have $90. in them and that's ok as I feel they'll last the life of the car. I'll paint the bars red.
Old Apr 1, 2010 | 07:53 PM
  #55
bunkie's Avatar
There, all done.
Old Apr 1, 2010 | 07:54 PM
  #56
TEB-HHR's Avatar
Those sure do look nice.
Old Apr 1, 2010 | 09:29 PM
  #57
Rainman's Avatar
Terry, I can't wait to see them installed
Old Apr 10, 2010 | 01:10 PM
  #58
bunkie's Avatar
installed
OK Byron, here they are
Old Apr 10, 2010 | 09:50 PM
  #59
IgottaWoody's Avatar
$10 a piece gets you a rod ready to go at Speedway Motors........matter of fact can bulid the whole thing from their parts..use regular heim joints and bolts..just have to boot them to keep em clean....
Old Apr 11, 2010 | 12:08 AM
  #60
Rainman's Avatar
Terry looks awesome, just ordered the engine mount in red/red w/black bushing. springs go in on the 19th, i'll send pics of before and after when done.
