rear helpers
Old May 7, 2008 | 07:54 AM
Ed RazorLite's Avatar
I cant fit the compressor for the airbags. The car will be filled with audio gear. I dont even carry around a spare tire.
I guess the best option would be coilovers but they are so expensive. Maybe one of my colleagues in the custom car world can make me some custom heavy duty springs.
Thanks for the help guys.
Old May 7, 2008 | 08:11 AM
GRUMPEE's Avatar
Originally Posted by jeffs396
Send fontana motorsports a PM...he's got some kind of helpers in the rear of his panel.
FM's got a bag in each spring but no compressor. Each bag is set up with a tire/schrader accessible via the rear tailight access panels. So when he adjusts for a load it's just like adding air to a tire.
Old May 7, 2008 | 02:36 PM
Snoopy's Avatar
Yeah, what FM's got is a good method for additional handling and weight control. I used it in several cars with remarkable results.
The bags are heavy duty Rubber and fit inside of the coil springs. The air line leads can be led to a "mutual" schrader in the gas cap filler area. If I remember correctly, the bags held 20-25 PSI total.
The bags are produced by Firestone and AirLift.....can Be purchased from JC Whitney if you can't find them locally. However, there is no listing for the HHR or Cobalt the last time I looked. But, if you had the inside width and length measurement of the coil spring, Whitneys technical people could help you.
But as for your additional weight, I'm not sure 1500 pounds in the rear cargo area is a good idea....or can be overcome logically.
Old Sep 12, 2008 | 12:15 AM
freshone's Avatar
coil springs
i was wondering if anyone knows the height and width of the rear springs so that i could get the spring bags
Old Sep 18, 2008 | 04:21 PM
IgottaWoody's Avatar
See my post in Gen HHR under towing....you need the bags for an early 90 Cavalier..they are 4" by 4" and sit sideways in the spring..uses the bumper stops as cushion... sounds odd but works good...
Chillydip
14
May 8, 2015 07:23 PM
oldracer
Maintenance and Upkeep
10
Feb 7, 2014 01:06 PM
Rob
Aug 31, 2006 10:41 PM
crowbar
45
Aug 10, 2006 09:44 PM
