Rear Suspension
Old 01-21-2011, 06:35 PM
wildman1122's Avatar
Rear Suspension
my 2006 lt Hhr just got hit and it bent the rear axle so I have a chance to buy 2008 SS rear end and I am wondering other than the obvious will it bolt up to the point that is just little thing like brakes that I will have to mess with Thx Guys
wildman1122 is offline
Old 01-21-2011, 06:54 PM
I think so..... there's been a few guys do this as a modification and if you are getting the whole unit, brakes and all, it should be a bolt in.
Greybeard999 is offline
Old 01-21-2011, 07:21 PM
Ya I am getting everything Spring Shocks Rotors completely assembled axle the insurance co want to pay me and let me keep car and the body shop says nothing else wrong but axle and some sheet metal and I always wanted to change to disc brakes on the back anyways !
Old 01-21-2011, 08:00 PM
bassbase's Avatar
Do it. Would be a very nice free upgrade.
bassbase is offline
Old 01-21-2011, 09:47 PM
Old 01-21-2011, 11:45 PM
Might need to consider an SS proportioning valve for the switch to discs in back.
sleeper is offline
Old 01-22-2011, 01:10 AM
Just remember to upgrade the front suspension to match the rear spring specs or you'll end up with some interesting handling traits. Probably just need to change out the struts and springs to SS spec units and you should be good to go.
843de is offline
Old 01-22-2011, 01:24 AM
HipHotRod's Avatar
Add one -
I think Id compare part numbers on the master cylinder as well. Certainly worth looking into.
HipHotRod is offline
Old 01-22-2011, 09:06 AM
1Panel2NV's Avatar
http://www.cobaltss.net/forums/suspe...n-done-165238/
Check out post 24 and 25.
1Panel2NV is offline
Old 01-22-2011, 09:39 AM
nacademus's Avatar
Isn't there a difference between break pressure applied to drums versus discs? You may need to get the proportioning valve too, no?
nacademus is offline
Quick Reply: Rear Suspension
