Removing EBCM harness from EBCM
2009 HHR SS
I need to test a connection on the EBCM harness, but haven't figured out how to remove the connector from the EBCM. I don't want to break it while trying to remove it.
Any info that you can post or photos as to hoe to safely remove the connector would be appreciated.
I am pulling up codes
c0045 left rear wheel speed circuit
c0110 pump motor circuit malfunction
The left rear hub was just replaced last week. code was cleared and immediately showed up again. Pump code also immediately showed up as well.
Dave Buchholz, Rochester NY
