Strut bushing n bearing
Old May 31, 2012 | 03:37 PM
capp002's Avatar
has anyone had a issue with the strut bushing and bearing, if so what kind of noise did you get from it? thanks
Old May 31, 2012 | 03:54 PM
There have been folks here with ones that have gone bad capp, the noises seem to be creaks, cracks, clangs, rattles, "thongs", and crunching when the wheel is turned.
Depending on the mileage of the capp-mobile, its probably a good idea to change out the strut mounts when doing struts, they tend to dry out and lose their lubrication over time.
The mounts in my '06 were toast at 89,000 miles, while the ones I replaced in the '07 at 60,000 were still OK, but it was a case of "while I have it apart, might as well replace them".
Old May 31, 2012 | 04:04 PM
badassbowtie's Avatar
Mine does it and has been diagnosed....i think "thong" is the right description of the noise. you should feel it in the steering wheel as well
Old May 31, 2012 | 05:25 PM
capp002's Avatar
thanks 843 n badassbowtie, the capp mobile has 13000 miles, im sure its the bearing everytime i turn the wheel left or right i get this dry bearing sound(clunk). i put konis all around the car i should of had that replaced them my fault thanks guys
Old May 31, 2012 | 07:11 PM
VinceP's Avatar
I just replaced the strut mounts with the struts. They were not expensive so like 843 said, while I am in there make everything new.
Old May 31, 2012 | 11:47 PM
IgottaWoody's Avatar
Yup..they dry up and get grit in them...changed mine and u can feel the grittiness in them....
Old Jun 2, 2012 | 10:11 AM
capp002's Avatar
thanks everyone, getting them replaced tomorrow
Old Jun 3, 2012 | 01:13 PM
capp002's Avatar
ok heres what i got i replaced the strut bushings and bearings. noise still remains its coming from the top of the strut. im so lost dont know what to do
Old Jun 3, 2012 | 02:35 PM
VinceP's Avatar
Very strange. Did the noise change any at all or does it sound exactly the same?
Old Jun 3, 2012 | 02:52 PM
Make sure that the noise is in fact coming from the top. Some noises can originate from one spot and the noise "travels" along a solid part and then seem to come out elsewhere.
Check the lower end of the strut and the surrounding suspension. One way is by taking a handhold and feeling for the noisemaker. If it makes a noise, it will also cause vibrations. You should be able to feel it. Just be careful and don't get your hand pinched or crushed.
Good Luck. Keep us posted.
