Suspension Newbie
Old Apr 4, 2018 | 11:18 PM
Tractorsmith's Avatar
Originally Posted by Silverfox
I think You will have to order two #5 Jounce Bumpers on the "diagram" in order to get the Top Isolators.
They do not sell them separately.
Silverfox
Thank you, you guys are great. Very helpful. Thank you.
Old Apr 5, 2018 | 09:35 AM
Cat Man HHR's Avatar
Originally Posted by donbrew
The isolators do wear out and make noise.
Which part do you call the isolator ? Top or bottom ?
I'm guessing bottom.
When they do wear. Is it the material that there made of that is the problem ?
Old Apr 5, 2018 | 10:08 AM
The bottom is rubber, and it does wear out. Check out the diagram above. It has all parts labeled.
Old Apr 5, 2018 | 10:33 AM
Actually, they are a hard plastic. The top or jounce bumper has an extra foam type ring that the spring seats against. That foam ring (white part in the picture) is what I consider to be the isolater.
Old Apr 5, 2018 | 11:55 AM
And I was generalizing calling anything that bufffer a spring and its seat an isolator.
Old Apr 5, 2018 | 11:56 AM
  #26
Silverfox's Avatar
Yes ... the isolator is on the Top Jouncer.
Be Sure to match the Jouncer to the proper spring.
Example.... If you are using rear Cobalt SS replacement Springs # 10390024 to lower the HHR, they use a different upper Jouncer with a shorter bumper.
I just put these on the rear of my 2LT and they make the HHR look much better.
It is the softer SS spring version and am completely satisfied. Approx. 1-1/2" drop.
I also added a TTR rear sway bar and that finished stabilizing the rear.
Silverfox
Old Apr 5, 2018 | 09:59 PM
  #27
That has been my experience as well, gotta get both.
I've had the rear TTR bar on mine since about '09, that & the Cobalt SS/TC rear springs, excellent combo on my 2LT Panel.
Old Apr 5, 2018 | 10:27 PM
  #28
Silverfox's Avatar
Hi Sleeper,
Have not seen you post for a while...
Good to see your still around.
Silverfox
Old Apr 5, 2018 | 10:43 PM
  #29
Hello SF- Yes been too long. Thank You, good to be back around.
Old Apr 5, 2018 | 10:54 PM
  #30
SwaintaN
57
Jul 21, 2013 10:21 AM
JMichael
Oct 23, 2012 05:19 PM
WickedHHRLT
Jan 23, 2007 10:57 PM
