Suspension recommendations for 1LT, 1LS, and 2LT HHR's
Old Aug 14, 2010 | 05:30 AM
I've read that the KYB shocks and struts are FE3 spec replacements..... you may want to give those a shot.
Old Aug 15, 2010 | 12:25 AM
RedLine's Avatar
I just did the Cobalt SS/SC springs as I've seen on some other threads, like the Lowering with GM parts thread. The results were 1-1/8th inch in the back and only 1/4 inch in the front. The ride quality hasn't changed but , I'm a bit disappointed that it didn't drop the 1 inch in front like I expected. I don't think it will settle 3/4 inches in front anytime soon. Springs were less than $40 each, new.
Old Aug 18, 2010 | 07:16 PM
farmer52's Avatar
I have not been under my HHR (too lazy). Does the 2LT sport suspension include a rear sway bar? What is special about the sport suspension (other than 17" wheels/tires)? TIA
Old Aug 18, 2010 | 08:10 PM
No sway bar on the 2LT... it has firmer shocks and struts.
Old Aug 18, 2010 | 10:52 PM
^ X 2 ^
All HHRs' have rear torsion bars, but no additional Anti-Sway Bar, like it should imo..
Old Aug 19, 2010 | 12:01 PM
tim_tenn's Avatar
Goldline leveling springs + TTR sway bar = better road manners, more fun in the curves and a more aggressive posture.
Old Aug 25, 2010 | 03:32 PM
I just installed a Progress Bar on the back today (Got a used one from a forum member, Thanks Clarke33 ) I only took it around a few blocks so I could check the torque on the bolts after a few turns and bumps..... MAN! this thing stays FLAT...... Very impressed so far. Can't wait for some twisties
Took about a half hour, didn't even lift the car....... It took so long because fiddling with the plates while holding up the bar and starting the bolts is tricky with arthritis and a bad back...... After getting the 4 bolts started I took each out, one at a time, added some locktite and then torqued them down.
Piece of
So far I've added the bar, lighter wheels and sportier tires to the FE3 "sport" suspension and it's a totally different car.... Heck I was impressed with the stock 2LT...
Old Aug 26, 2010 | 12:10 AM
T/C springs, TTR bar & major improvement in handling & looks.
RatRodS
May 3, 2021 12:46 PM
JMichael
Oct 23, 2012 05:19 PM
Cedavis81
Jun 24, 2012 07:55 AM
c2vette
Tires & Wheels
33
Jul 26, 2009 09:21 PM
ClassicWalt
Nov 27, 2007 08:52 PM
