Sway bar hits lower control arm?
because the rubber being spongy in the original sway bar bushings, will cause your sway bar contact issues, I have the Energy Suspension greaseable sway bar 25 mm bushings in my 2007 with 1.5 inch lowering springs with out the shims and the sway bar does not contact the LCA, so , if the if you start out without the shims and everything is fine then job done, or if there still is contact (which I doubt) then you have the option of installing the shims as required
