Wheel Bearings preload
The "axle nut" has nothing to do with wheel bearings. It is what retains the axle shaft. You can remove the axle nut and take out the axle shaft and the wheel bearing will remain bolted to the knuckle and not affected.
The wheel bearing assemblies are adjusted and sealed during manufacturing. They cannot be serviced in the field.
My argument here is that while preload may not be "adjusted" as in years passed, it is still "maintained" or "preserved" by the axle/axle nut/torque combination.
They also cannot be serviced in the shop, only replaced!
The fact is...the new generation bearings (as on HHR) also no longer require the axle shaft to keep them together. They work as well either with or without the shaft. It's a new method of manufacturing that you may not be aware of yet.
A practical demonstration of this is in the front spindles of the RWD Solstice and Sky. They have no axle shafts, but are the same bearing/hub assembly as used in the Cobalt and HHR.
Just to clarify: On some earlier FWD vehicles, a loose axle nut can lead to separation of the inner and outer bearing races and loss of as-manufactured bearing preload. However, the new generation of these bearing assemblies, such as used on HHR, are independent of this requirement, and will not separate, even without the axle nut.
Almost true...at least as applied to older vehicles than HHR. However, your point was about assembled axle nut torque affecting or being critical to assembled bearing preload, as in more torque can produce more preload and therefore possibly damage the bearing. This is Not true.
A practical demonstration of this is in the front spindles of the Solstice and Sky. They have no axle shafts, but are the same bearing as used in the Cobalt and HHR.
It's a unique setup for sure. Whereas one could press apart the previous generation FWD bearings that required the axle shaft to stop the bearings from separating, the new generation bearings are not able to be disassembled. I won't claim engineer-level knowledge of this new bearing assembly technique, but to me it appears that once assembled, the inner hub is then swaged outward to capture the opposite side bearing.
On the other hand, if I saw a tech impact my axle nut, I would request a new part and a new tech or at least one who was teachable. I've just seen these "simple" repairs go south to quickly when procedures were not followed. If I'm going to pay dealer labor rates, I want things done "by the book".
Does the word trolling have any meaning to you on this part of your post? I hope that's not the action you were trying to accomplish.
