2006 - HHR 2.4L with P0700 and P0741 code
Old May 24, 2019 | 09:39 PM
guille2228's Avatar
Hi, guys. Been looking on the web and on here, but haven't found an answer to this problem. Car drives fine for the most part. Wife says she hears an noise when she is accelerating fast.
Been reading around that it may be a bad TCC solenoid. Where is that located? Any suggestions would be greatly appreciated.
Old May 24, 2019 | 10:11 PM
Assuming that the codes in the title are codes you pulled from the car.
P0741 means the Torque converter clutch is stuck OFF. i.e.: you don't have overdrive.
Unless you have a lift and some mechanicing experience you need a pro to do it. There are some complicated tests to be sure which part is bad. A fluid change might fix it.
Here are SOME of the reasons for it.
Old May 24, 2019 | 10:43 PM
guille2228's Avatar
Thanks for the fast reply. I was afraid of that. I did do a fluid/filter change of the trans hoping it would help, but it didn't. I cleared the codes, but them came back after a drive on the highway.
Old May 25, 2019 | 12:17 AM
guille2228's Avatar
One more question. Where is the TCC solenoid located? Its driving me crazy.
Old May 25, 2019 | 08:14 AM
FastSUV has a how to in this thread
https://www.chevyhhr.net/forums/driv...d-61313/page3/
#312 in this diagram
Old May 25, 2019 | 09:09 AM
335 is the actual solenoid. 334 is the valve. 339 is the regulated apply valve.
Old May 25, 2019 | 01:24 PM
Those are the shift solenoids, the TCC is 312 in that diagram also
Old May 25, 2019 | 02:18 PM
This is my source:
The 2 305s are the shift solenoids, 312 is the pressure control solenoid
Old May 25, 2019 | 08:12 PM
Yes , I see the valve and solenoids
Old May 26, 2019 | 12:13 AM
guille2228's Avatar
Wow, awesome information! Thank you!
Tye
Mar 18, 2019 10:08 AM
Wifes07LT
Jun 13, 2018 04:52 PM
George1
Nov 21, 2017 06:22 AM
Salcov
Jun 3, 2016 09:27 AM
clwest25
Jan 7, 2014 07:54 AM
