69,000 miles and synchros gone
Old Jan 15, 2012 | 10:20 AM
Hib Halverson's Avatar
HI all-
My Wife's HHR has a five-speed manual and, at 69000 miles, it's begun to have trouble with grinding going into second on up and downshifts and into first on downshifts.
No clutch problem that I can detect so I figure the trans needs 1st and 2nd gear synchros.
Has anyone else, here on the HHR net experienced synchronizer ring failure(s) at 65000-75000 miles?
Old Jan 15, 2012 | 10:42 AM
At a dead stop, does it go into 1st gear easily & no pulling ?
Old Jan 15, 2012 | 01:27 PM
I'm thinking a problem with the clutch slave cylinder or throw out bearing rather than the synchros in the transmission. I believe this is the same train of thought that Sleeper is having, if you're at a dead stop and it binds up going into first with the vehicle trying to lurch a bit, your clutch isn't disengaging fully causing the grinding you've described.
Old Jan 15, 2012 | 03:00 PM
Snoopy's Avatar
Hib.....
Tell your wife to stop "banging" gears !!!!
Old Jan 15, 2012 | 05:37 PM
Old Lar's Avatar
I have a 25 year old car that has the original syncros. I have replaced the hydraulic master and slave cylinders. Also have redone the clutch, throw out bearing, flywheel shaved etc.
Old Jan 15, 2012 | 09:56 PM
Hib-
My last Chevy S-10 (1998) started to require just a tiny bit of effort to put in first gear at a dead stop, & when in 1st, I could feel it wanting to crawl very slightly..
Been there before..
It had no slave cylinder or master cylinder external leaks. But the slave was obviously wearing out & the fluid was by-passing (internally) & when released it would draw back into the reservior in the slave..
So it was an R&R dealio.. Of course the slave being inside the bellhousing (like hhr), tranny removal was necessary...
On that truck it wasn't a big deal to R&R it..
fwiw: I don't "think" it's synchros..
Old Jan 16, 2012 | 11:25 PM
Goes into gear at a dead stop like a knife-through-butter.
Old Jan 16, 2012 | 11:26 PM
No problem getting into a gear at a dead stop, either 1st or reverse.
The problem is only with 1st and 2nd not the other four gears so that sort of rules out a clutch issue. If I had a clutch or clutch slave problem, I'd have hard shifting in all gears including reverse.
Old Jan 16, 2012 | 11:55 PM
well, sounds a lil more serious then.. Warranty ?
Old Jan 17, 2012 | 01:18 AM
X 2, Sleeper and I both thought you had a clutch issue, but now it sounds like you've got a transmission starting to pack it in on you.
