Axle Seals in Transaxle
If you are not changing axles , you don’t need to worry about the stub shaft on the tripod.
wipe it clean and smear a little ATF or grease in the seal surface, and be careful not to damage the seal.
Sounds good for the passenger (right) side. What about the driver (left) side? Does the stub shaft need removed from the tranny? If so, how? Or should I just install the new output shaft seal and leave the stub there in driver's side?
Apparently only one stub shaft , on the passenger side
GM AXLE STABILIZER BEARING / SEAL, 4T40E & 4T45E
When I get home, I'm going to spin the splines in the tranny to see if the outer sleeve turns with it. I hadn't checked that yet, but that will confirm it's a stub shaft on the driver's side.
My axles came out with no stub shaft on either side, and the seals weren’t damaged, so I haven’t seen a stub shaft for the drivers side.
According to this , that side is a fixed shaft
https://www.chevymalibuforum.com/for...tub-shaft.html
