Clutch replace
Old Oct 15, 2016 | 07:37 AM
Originally Posted by Don_Meier
Where can I get a workshop manuel for clutch replacement?
Check your PM.
Old Jun 17, 2017 | 08:23 AM
esmarkey's Avatar
I know this is an old thread, but I think I have a bad throw-out bearing in my SS... If I have to replace that, might as well put in a new clutch kit. I looked up the Exedy site, and they do not one. Has anyone had any luck with a particular kit?
DonBrew, do you have access to a manual for clutch replacement?
Old Jun 17, 2017 | 09:22 AM
Check with Aaron
Turbo Tech Racing - Experience The Boost! - Turbo Tech Racing
Old Jun 17, 2017 | 10:17 AM
esmarkey's Avatar
Originally Posted by hhrfreek
I put one in last winter. You may need an extra set of hands at times when handling the transmission. Some of the bolts are a real PITA to get at and loosen up as well.
I am dropping the sub frame once again as well this January. I am pulling the motor for some forged parts and throwing in another clutch. Any questions let me know.
You'll notice the clutch will say Daiken on it, which is Exedy and they offer an OE replacement as well as staged clutches. The OE part number from Exedy is GMK1010. Get the flywheel machined as well. Should run about $65 bucks at most shops. The flywheel bolts are also TTY. If you decide to machine the flywheel you will need new ones...$6.50 a bolt...and you need 6
What is TTY?
Do I need to replace the flywheel bolts regardless of whether I machine or replace the flywheel?
Old Jun 17, 2017 | 10:22 AM
Originally Posted by esmarkey
What is TTY?
Torque To Yield. Basically the threads deform when installed to lock in, so, yes replace.
Actually, Mitchell says they are "prevailing torque fasteners" and they may be reused IF:
The last spec is the one that is tough to determine, so safety says replace.
Old Jun 17, 2017 | 10:48 AM
esmarkey's Avatar
Attachment 21903
That's what I thought... Is this the correct bolt?
Thread Size: 7/16-20; Thread Length; .900" (22.86mm); Head Thickness: .190" (4.83mm)
Old Jun 17, 2017 | 11:20 AM
As far as I know all of the fasteners on an HHR are metric, you are showing SAE sizes.
https://www.gmpartsgiant.com/parts-l...ae35d2daf3bb4c
Hotrodbob
Sep 29, 2014 06:58 PM
Denne
Jul 2, 2014 04:26 PM
07azhhr
Nov 10, 2011 02:55 PM
Chevy_dork04
Apr 14, 2010 12:51 AM
dmoney
Oct 30, 2009 11:22 AM
