dead pedal syndrome
Old Jun 25, 2013 | 04:31 PM
cannuck's Avatar
dead pedal syndrome
from other thread reads i will start with the clutch master cylinder. easy to get at and seems most logical.
gm part $72
knock off $32
advice on purchase, get 2 cheaper or the gm and hope it lasts as long as 2 cheaper.
symptoms
-pedal stays half pumped
- to the floor shifting
-difficult engagement
Old Jun 25, 2013 | 04:49 PM
I'd go with the GM part just because of the duty cycles it sees, and do you really want to change it more than once?
Old Jun 25, 2013 | 05:41 PM
I'd guess the $32 is rebuilt. I would not care because it is the $1 worth of seals that wear out. There is no wear on the metal parts, except for the spring and pivot joint.
Old Jun 26, 2013 | 08:49 AM
Rod Run's Avatar
I'd go GM without even thinking about asking the question that you did... but that's just me
Old Jun 27, 2013 | 06:23 AM
Tominator's Avatar
GM doesn't manufacture it and there may be several different suppliers during the life cycle of GM buying the part. IMHO there will be no difference in quality.
Old Nov 17, 2013 | 11:19 AM
bikersteve59's Avatar
I doubt that there are any rebuilt units, as they are made of plastic.
DangerBoy
10
Oct 2, 2014 08:18 PM
stowell1976
May 7, 2012 03:37 AM
Marcruger
Nov 8, 2009 08:34 PM
Marcruger
Sep 20, 2009 07:19 PM
chooch
Jan 22, 2008 04:47 PM
