Overdrive not engaging
Old May 20, 2013 | 12:32 PM
cornwalis's Avatar
it should be better now I got the voice typing working on my phone. maybe you're staying shift linkage is off buy a bit there's also two shaft speed sensors and a temp sensor I had a car oncethe two sensors went on it and I had no first gear did you try unplugging the power from your battery for 10 seconds to see if it resets the computer maybe you'll get your overdrive backhope you can understand this post this time sorry for the other one
Old May 20, 2013 | 12:39 PM
Snoopy's Avatar
Heard of this many times and I'm amazed at the owners when they say, "Gee, what's wrong".
In my experience if the trans fluid is not to bad.......lost most of it's properties and viscosity....a transmission flush and fluid change MAY correct your problem. Generally, when shifting gets sluggish, and in some cases, none existent, the fluid lost viscosity.
Old May 20, 2013 | 09:47 PM
:) at least you try man. :)
Yeah, keyboard might work better for you.
Old Jul 20, 2013 | 10:03 AM
nate71's Avatar
Thank you all for the help, trying today, will post results
Old Sep 11, 2019 | 06:10 AM
Treble Hook's Avatar
what was the problem? did you ever get it fixed?
Old Sep 11, 2019 | 07:48 AM
Doc brown's Avatar
You do realize that you are replying to a 6 year old thread? The OP has not posted again since so not very likely you will hear anything back.
Jessica Rogers
Aug 16, 2019 08:10 AM
Danny Thomas Sr.
May 27, 2016 01:07 PM
mike1955
Aug 27, 2015 03:49 PM
HHRMom_0791
Jul 14, 2014 07:38 PM
55f250
Maintenance and Upkeep
Aug 21, 2010 11:10 AM
