Service traction control light
Old Feb 25, 2020 | 05:16 PM
The basic theory is that most sensors run on 5 Vref. If there is not enough juice to keep the ref to EXACTLY 5 V the sensors will not work. The computers need 9 V to even think about booting, and they draw more amps while booting. A weak battery will draw down a lot with a little load the 5 Vref circuit is designed to deliver exactly 5 V if it is supplied with X Volts; resistors are stupid; they just drop the voltage/current they get by whatever value they are.
Most of them also use Lowref, instead of ground, that can be off because of the battery.
Old Mar 2, 2020 | 06:54 AM
Lethal Tendencies's Avatar
Replaced the battery. Its was dated 8/2015. So far so good, its been 2 days.
scubanut
27
Jul 9, 2024 09:51 PM
Eric Overmiller
Mar 22, 2018 10:07 PM
Alexwsilver2010
Aug 9, 2014 10:41 AM
Cascious King
May 8, 2014 08:50 PM
Fox Hat
Feb 7, 2014 07:39 AM
