Surges At Low Speeds
For a while, I've been experiencing my 2008 HHR will surge or lope at lower speeds - usually most noticable under 40 mph. I've also noticed when slowing down from highway speeds - like turning onto an off-ramp - there's a noticable down shift when speed drops below 60 mph. I've had the transmission flushed twice in its lifetime - would it help to actually remove the trans cover and replace the filter and fluid? Oh, yeah - it currently has 234k miles on it. Thanks, Rich
Okay, the obvious question: Did you forget to mention the Check Engine Light is on?
If not; my guess is one of the valves in the trans is mucked up.
No, I don't think a new trans filter would help.
Thanks, guys! No, there's no Engine Warning light or any other fault codes. If there were, I would have already the scan tool connected to see what was going on. The engine is still running like a Swiss watch, so I'm more inclined to suspect something going on with the transmission. Thanks, Rich
63falcondriver
Jun 29, 2012 06:49 PM
