Transmission Cooler line seals
Old Mar 7, 2014 | 03:11 PM
good job, up here the lines were $103.00 plus tax, ouch!
Old Mar 10, 2017 | 07:56 PM
Ricky Butler's Avatar
Did you have any trouble getting them out
Old Mar 10, 2017 | 09:50 PM
Nope!
Old Sep 11, 2018 | 04:21 PM
Quentin Traffie's Avatar
Originally Posted by Lucky
We are talking about the fittings that the line plugs into? Number 8
Does anyone know what the specs are for the nut numbered #2 in the image?
Old Sep 11, 2018 | 04:37 PM
Nut #2 in the diagram I tightened to 89 inch lbs
Old Dec 27, 2018 | 01:47 PM
  #26
jjoverit's Avatar
Originally Posted by Oldblue
Well I have to answer my own question, I replaced the trans line kit last Saturday, have driven about 275 miles since then no leaks at the trans seals in question or at the rad Kwik-connects. now to get the transmission fluid level double checked and I'm good to go!
how did you get them out?
Old Dec 27, 2018 | 01:55 PM
  #27
With a quik connect tool.
Old Dec 27, 2018 | 01:56 PM
  #28
jjoverit's Avatar
Seals
how did you remove the seals having a hard time
Old Dec 27, 2018 | 02:16 PM
  #29
The seals at the transmission? I pryed and used vise grips to grab them and work them out, not a fun job but it had to be done.
Old Dec 28, 2018 | 10:17 AM
  #30
jjoverit's Avatar
did you poke a hole in the center before installing, or does the line cut it enough to let fluid flow?
