Transmission Cooler line seals
Old Nov 23, 2020 | 06:09 PM
  #51
rfrumin's Avatar
OK. So - the good news: The lines are correct. I'm not sure how it appeared that they didn't at first, maybe the angle they sit at created some magical illusion.
The bad news: *DO NOT TRY TO REPLACE THOSE 'SEALS' mentioned above* (ACDelco 24221233 Automatic Transmission Oil Cooler Seal)! They are not seals, but rather pressed in metal bushings that are impregnated with rubber and IMPOSSIBLE TO REMOVE. Long story short, after destroying all the rubber of one them only to figure out they they're not coming out, I decided to go to depot and get some fat o rings and jam a bunch of them on the end of the line, Shockingly, it seems to be working. I imagine it's probably going to seep over time but it beats destroying the trans case over a $10 piece of steel and rubber.
The lines themselves are not bad to do. The radiator definitely had to come out for me to get those E clips off which were also somehow corroded. It wasn't too bad but I did need to go purchase the long hose clamp tool. A quick disconnect tool was not necessary. With the E clips out and the 10mm nut off both ends just pop out.
Old Nov 23, 2020 | 06:19 PM
  #52
There is a tool to remove and install those seals. I’ve done it, didn’t destroy anything.
the transmission filter seal is a similar fitting design.
https://www.autotoolworld.com/Kent-M..._p_210503.html
I rented the tool
Old Nov 23, 2020 | 06:28 PM
  #53
rfrumin's Avatar
Thanks...wish I knew that before I dug into it lol. Where did you rent it from? I can always pull those lines off just the trans and do it.
Old Nov 23, 2020 | 07:46 PM
  #54
I’m a long time GM dealership owners friend, I have an in with the service department, and they had the tool, similar to parts palaces.
KZig
Aug 9, 2015 01:21 PM
Cat Man HHR
Dec 28, 2014 10:18 AM
Tyler Harvey
May 14, 2014 06:02 PM
nuyork212
Mar 25, 2014 07:35 PM
desertrat
"How To" Tutorial Library
Nov 13, 2013 03:47 PM
