Transmission Cooler line seals
Old Dec 28, 2018 | 01:53 PM
  #31
jjoverit's Avatar
2422-1233 trouble
Originally Posted by jjoverit
did you poke a hole in the center before installing, or does the line cut it enough to let fluid flow?
well I got the bottom one out yesterday. But today its leaking I think I knicked the inside of seal when I installed it. About to go try again should be fun.
Old May 26, 2019 | 09:40 PM
  #32
Floyd M. Steiner's Avatar
Cooling lines
I’m having a problem getting the line out of the radiator. The bottom line wasn’t a problem. The top line is giving a problem getting the line out. It’s a 2009 hhr. Any ideas?
Old May 26, 2019 | 10:19 PM
  #33
Go to the local; auto parts store and get the Tool. It is basically a piece of plastic that goes around the tube and pushes the spring clip out of the way. Called quick disconnect tool. Or use a pick to pull the spring clip out.
They come in several different shapes, here are some:
Old May 27, 2019 | 08:27 AM
  #34
The retainer clip #7 , you can use a small screwdriver or a dental hook to move it , it will slide back , then remove the line.
Old May 27, 2019 | 08:57 AM
  #35
It's the top line that's giving him problems.
Old May 27, 2019 | 09:12 AM
  #36
They are the same.
Old May 27, 2019 | 09:42 AM
  #37
I have the the spring ring out already. Used a pick tool to get it out. But it’s not coming out.
Old May 27, 2019 | 10:54 AM
  #38
Try a shot of WD 40 or PB , then a gentle twist while pulling.
Old May 29, 2019 | 04:50 PM
  #39
Got the lines put in. No fluid came out when we took lines out. Put in 7 quarts of transmission fluid. It was still slipping when I drove around the block. Added 4 more quarts. Now didn’t move forward at all. Only had reverse. I believe there maybe to much fluid in it. Drained some it still didn’t move. It was coming our pretty good. May need to drain more out.
Old May 29, 2019 | 05:33 PM
  #40
Check your steps , 10 quarts? Way to much
https://www.chevyhhr.net/forums/how-...-change-58325/
