I got pushed into a trailer hitch on the freeway the other day on the way to work. The hitch hit the license plate almost straight in the middle. I had stopped about 3 ft from the truck in front and someone struck me and launched me into the truck.
Insurance isn't going to pay for the damages, so I thought I could replace the parts from the junk yard. Basically the inner bumper buckled and punched the A/C condensor/Radiator and Fan into a V-shaped sandwich. I lost all the freon and the radiator was trashed although didn't leak. Fan housing was broken and fan was frozen against the radiator. Luckily all the damage ended there.
Pick a part has "1/2 off" special this weekend and I was able to get the parts for $100.
I have never messed with a transmission cooler. I was able to get the lines off and onto the "new" cooler, but all or most of the fluid in the cooler leaked out on the trip home. Will the transmission just circulate the fluid into the cooler or am I going to end up with a vapor lock?
Also the fitting and hose look like high pressure - will a leak be evident at the fittings (I got the clip off and back on both the original and the replacement cooler, but I didn't see any rubber that seal that connection).
I don't want to drive the car if the transmission fluid isn't circulating.
