Transmission temp sensor?
Old Apr 6, 2014 | 07:21 AM
HHRNole's Avatar
I had put a Scanguge II in my car hoping to be able to read tranny temps while towing but I guess you can't read that function thru the OBD port. Anybody know if the 4T45e trans has a sensor to read temp or a overheated condition and if not can I add one to support a regular trans temp guage.Also where would I install such a sensor short of welding a bung in the pan? Also I'd like to install an engine oil temp guage too.
Old Apr 6, 2014 | 07:52 AM
The 4T-45E does have a TFT(Transmission Fluid Temperature) sensor already, but your Scangauge II may not have the software needed to interpret the data.
Give post #7 in this thread a read....
https://www.chevyhhr.net/forums/problems-service-repairs-42/no-cold-overdrive-45712/
TFT Sensor data is readable with a Tech II through the OBD II port, you might want to contact the Scangauge folks to see if they may have a software update available to read that data stream.
It's locked out on some scanners, just like SRS codes and data.
Old Apr 6, 2014 | 09:59 AM
HHRNole's Avatar
Thanks Mike
alexrckid
Jun 10, 2013 11:45 AM
SwaintaN
May 31, 2013 01:10 PM
alexrckid
Jul 6, 2012 07:27 AM
greg_h
Jul 5, 2012 07:58 PM
MikeX
Jun 12, 2006 02:54 PM
