TTR Upper Engine Mount
Just installed it. The old one was definitely shot with 80k on it.
I have not noticed more vibration, and admittedly have not track tested yet... But honestly, what difference should I notice? More planted? It should have been a night and day difference.... I'll report back after some time behind the wheel.
Install took about 45 minutes, with twenty of that spent with a trip to AutoZone.
If you do this empty the windshield washer reservoir, unless your ok with it spilling everywhere
Nice piece though, definite improvement over stock rubber. My OEM had stress cracks in several places throughout the rubber.
Thanks Aaron!
Thanks Aaron!
Not sure what to tell you about the vibration. Mine calmed down a bit after a while, but I can still hear/feel the engine more. When you romp on it and the tires are fighting for grip, it seems a little easier to keep it pointed in the correct direction. Both tires seem to bite at the same time.
If you pay close attention when first installed youll notice a bit more engine "noise" , but after awhile either from getting used to it or the mount loosening up its not noticed anymore....though it u ever get into 'lugging' rpm range it will remind you..
