Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
Is The Woolly Worm Needed?
Old Jul 10, 2010 | 10:22 PM
IgottaWoody's Avatar
now...nobody said it wouldnt stand a slight size ( dia) increase...............
Old Jul 10, 2010 | 11:11 PM
prod's Avatar
Is that what she said, mr "Igottawoody"?
LOL had to say it.
Old Jul 11, 2010 | 09:14 AM
welll............ok got me
Old Jul 11, 2010 | 09:41 AM
JoeR's Avatar
The wooley will not change milage from a restriction point.....removing it will only suck air from the bay area....though i dont wholey agree on it being that hot as when the vehicle is moving so is the air and the heat is behind the motor with the air exiting to the rear.........I think a thermocouple ie needed and in real life conditions not a dyno.....air does funny things with slight changes...
When the infamous CGS hot air intake was the rage a few years ago, I did exactly that. Setup a digital thermocouple to take measurements at a few points. Air temps were in the 30 - 50 degrees hotter range when the air was sourced underhood instead of the fenderwell. SAE computations indicated a loss of 4 - 6 HP with that. I also confirmed that on a dyno. Air doesn't do "funny things". Changes in air density due to temperature is a known scientific fact.
BTW, the stock intake system is NOT restrictive either. Have data to prove that, too.
Old Jul 11, 2010 | 10:05 AM
urbexHHR's Avatar
But from what I've read online about hot air intakes, you lose hp, but gain mileage.... Is that correct?
Old Jul 11, 2010 | 10:32 AM
"you lose hp, but gain mileage.... Is that correct?"
I wouldn't think so.......
Old Jul 11, 2010 | 11:52 AM
Marcruger's Avatar
I agree with GreyBeard. If an engine is more efficient, it will make more power. So, if the car loses horsepower due to higher underhood heat, then you'd have to press the pedal harder to accellerate the same or maintain a constant speed. That would logically burn more gas. I have long heard that making an engine more efficient (with more horsepower) will also give it more mileage. Just my 2 cents worth, and I am no expert at anything. God Bless, Marc
Old Jul 14, 2010 | 10:12 PM
Air does funny things was in referance to airflow not density......or temp.......a moving vehicle will flow air differently then a stationary one....usually
crawley595
Jul 12, 2022 09:08 AM
aeroned
Apr 6, 2015 02:57 PM
Banshee77
Jul 11, 2011 08:41 AM
foolmoon_design
2.0L Performance Tech
14
Jan 3, 2011 05:27 PM
Lee3333
13
Sep 13, 2008 09:54 AM
