2008 head fit a 2007 hhr engine?
Old Feb 28, 2010 | 09:47 AM
dawnstulee's Avatar
i have a 2008 hhr 2.4L engine that has a rod knock. i bought a 2007 hhr 2.4L to replace it. i want to be sure the heads are interchangable before i go to all the trouble. also, for the gasket, the only one i could find is for the hhr LS, mine is an LT. are they the same engines? the reason i have to change the head is because the 07 has one cam sensor and the 08 has 2 cam sensoprs. can i take the head w/ the 2 cams from the 08 and put them on the 07 block? thanks for all replies :)
l
Old Feb 28, 2010 | 03:48 PM
dawnstulee's Avatar
PLEASE i need the answer as soon as possible. does anyone know?
Old Feb 28, 2010 | 05:32 PM
wolfman's Avatar
If you have a 2008, why are you paying to fix this when you have a 100k mile warranty?
Gas
Aug 24, 2015 06:47 PM
JenuwineHHR
Mar 29, 2014 09:58 AM
bhamsoxfan
Nov 24, 2013 11:12 AM
billynad
Jul 2, 2013 07:55 AM
