2008 HHR - bit of gas fume
Old Jun 16, 2020 | 02:22 PM
TechBill's Avatar
Sorry for not updating this thread. The gas fume stopped and it never returned so we have forgotten that we had this issue!
So far, no fumes
Old Apr 8, 2021 | 11:42 AM
KOV's Avatar
KOV
Gas Fumes
I've been battling a similar gas fume problem on my 08, 2.4L, panel for the past year. I smell strong fumes inside the cabin and outside the vehicle. It started slowly, barely noticable, then over months got worse to the point I can't stand driving the vehicle.
I hoped it was the typical rusted fuel line, which would be easy to diagnose, but no visible leaks or puddles underneath. I live in Az, very dry climate and no salt on our roads. Also no OBD codes thrown for this issue. I have had the cam position codes that I can't seem to permanently fix, but I don't think that's related. I had those long before the smell started.
I've checked the vent solenoid under the hood (whatever it's called). Wiring and valve seem to function with no problems. Put it up on ramps and investigated in earnest with a flashlight and my nose. Only thing I could find was slight oily staining just on the top rear edge of the gas tank. Just a slight fuel smell but nothing like I get in the cabin.
decided there had to be some kind of leak on top of the tank so I pulled it out. I live down 4 miles of dirt road so a lot of caked dust on top of the tank. No evidence of any big leak but could tell fuel had soaked into the dust some.
With the tank out and tipped on its side, fuel would start to wet around the 3 vents, they are yellow plastic, all connected by hoses. This is the only leak I could find and its very subtle. These 3 vents do not appear replaceable. Could find no part # for them, so I researched glues that would adhere to the poly tank and have glued around each of them. Also topped the glue off with a layer of silicone. We'll see if this fixes it.
Another note; when removing the purge valve off the vapor canister, a lot of dust was inside this valve. Maybe 1/2 a cup of fine powdery dust. Everything I've read says I should've had a code thrown by that, bit no codes. Maybe the dust plug is related bit I still don't know how/why fuel smell was so bad in the cabin.
Old Apr 8, 2021 | 02:14 PM
to the forums!
So you have a fuel leak, and a timing chain issue. You should not operate the vehicle until both of these are at least diagnosed.
Old Apr 8, 2021 | 03:42 PM
Rusty fuel lines and vapour lines are usually located under the insulation sleeve up above the axle, that’s where both my 2007 and 2011 had fumes coming from,
https://www.chevyhhr.net/forums/how-...follies-62310/
the smell of fuel was there for about 3 months, then the pin holes opened in the pressure line, bingo!!
That’s the EVAP canister, the black plastic and metal bracket, the lines are above that the insulation sleeve is just in the upper right of the photo
Old Apr 8, 2021 | 05:07 PM
KOV's Avatar
KOV
to the forums!
Thanks for the welcome. Yes, this is my extra vehicle and I can't even stand to drive it with the fuel smell. It's very strong in the cabin. The timing issue doesn't seem to affect drivability but I'd still like it fixed too.
Old Apr 8, 2021 | 05:24 PM
A timing problem is not just a nuisance. If ignored, you could end up buying a new engine.
Old Apr 8, 2021 | 06:32 PM
Timing chain and balance shaft chains are fairly easy to replace!
https://www.chevyhhr.net/forums/how-...in-kits-60394/
KOV's Avatar
KOV
Rust is not a problem in my area. I'm the original owner and primary driver. So far driven 150k miles.
Fuel lines above rear axle with fuel tank removed, looking toward the driver side rear.
I see no evidence of rust anywhere except surface rust on unpainted components.
I've also looked for wear caused by vibrations on all the fuel lines. None seen that might possibly wear through.
The leaks found around the fuel tank vent components seem to be my best bet so far. Through the searches I've done, fuel smell is usually from the rusted fuel line problem. No mention of leaks around the 3 yellow fuel tank vents.
Old Apr 8, 2021 | 06:36 PM
Maybe the plastic vents fatigued from the AZ heat? Could you post a photo of the repair if the tank isn’t back in position.
Old Apr 8, 2021 | 06:41 PM
KOV's Avatar
KOV
I'll add pictures of the top of my fuel tank to show the yellow vents I'm talking about and how I've attempted to seal the small leaks.
Closer view of one vent.
08 Fuel tank, yellow vent components have been glued around their perimeter with silicone on top of the glue.
