2LT to SS body conversion
Old Jul 29, 2021 | 10:22 PM
No adaptors or spacers needed. They are 17x8.0, 35mm offset. Won’t clear the Brembos on my SS, pretty sure they would cite a non-Brembo SS.
I bought them used. Discontinued product. I know of one other HHR with those wheels. Would like to buy a spare if I could find one.
Thanks for reply. Naturally they are discontinued , they look hot.
Old Aug 2, 2021 | 09:12 AM
PulpFriction's Avatar
Originally Posted by jjtjustinjjt
Looking at Hahn Racecraft t to possibly rebuild my 2.4!
Well that does change everything. If you’re going that far, forged rods and piston will make your 2.4 tolerate a turbo to make use of the new-found intercooler cavern. No SS clone derision. You’ll have a sleeper that will blow the doors off a “real” SS.
Old Aug 2, 2021 | 08:11 PM
jjtjustinjjt's Avatar
Yeah, I thought about doing the turbo after rebuilding. However, that's a lot of money. I actually have been donating plasma to get money to work on my car! HA! I get about 4-6 hundred a month and been saving every penny since February to get it painted. I do small woodworking projects to that's also made me about 3K in the last year. I've already spent about 1500 on parts and I need another 8 hundred before paint. Once those are done I'll be posting a before and after shot. Anyway, upholstery is next sometime next year. Engine is last on my list unfortunately unless I win the lotto!
Old Aug 2, 2021 | 09:33 PM
Cool, I believe the 2.4 has forged rods stock, but not pistons.. Do it up right.
Old Aug 3, 2021 | 08:30 PM
letterman7's Avatar
Originally Posted by Lonwane
But without rear disc brakes.
Which by the way was a PITA, and expensive, but, I have rear disc brakes.
Nah. Cheap if you take the time to look. Scored an entire rear axle assembly from a Cobalt SS on eBay for under $300. Car had less than 60K miles on it. It took another $100 for stainless flex brake lines to be safe, and about an hour to swap the axles out. Easy-peezy. I even snuck in lowering springs from the SS....
Old Aug 3, 2021 | 09:18 PM
There was a member from ancient times here, JoeR, that put a S/C on his otherwise Stock 2.4L & it help up fine, according to all his posts & etc.
Old Aug 4, 2021 | 08:46 AM
A&P was in the middle of getting all the pieces for a S/C install, sadly he passed away prior to completing his project. I think CJ Krause installed a S/C on his first HHR.
I’ve thought about it , but parts are scarce and it is a 10 year old car, and I’m in a fixed income now, so funds are just as scarce!
Old Aug 4, 2021 | 09:07 PM
Blue- You would have dug seeing JoeR S/C set up on his 2.4L.
Yes sad about A&P, I know he was gathering.
And CJ put one on his 2.2 '06.
Tristan Phillips
May 19, 2020 09:24 PM
HotrodHHR
30
Jan 8, 2018 08:55 PM
reno
Sep 11, 2015 07:16 PM
carranza1987
Mods - Exterior
Jun 20, 2013 01:21 PM
American & Proud
Mar 14, 2013 06:26 PM
