after the warranty then what
Old Nov 14, 2008 | 12:34 PM
chevyman's Avatar
i have not posted but a few times since becoming a member.but i fill the love for the hhr.some have left but new ones join everyday. they listen, look, and search for answers.my question is if you had issues when you had the warranty? what do you with the same issues when the warrant runs out.
Old Nov 14, 2008 | 12:40 PM
ChevyMgr's Avatar
If you are have the knowledge and tools you fix them yourself or you can buy an extended warranty. I find the manufacturers warranty to usually trump all others in coverage and ease of use. For GM it would be GMPP.
Old Nov 14, 2008 | 02:04 PM
an08HHR's Avatar
I think what is being said is, if you had a problem covered under warranty and then that same problem appears again after you are out of warranty what do you do. Usually the dealer will work with you and cover it again but that depends on how much time/miles have been put on the car since the repair.
Old Nov 14, 2008 | 03:10 PM
hyperv6's Avatar
You ask the dealer if it is still covered or not. Some items they will address even if the car is out due to the warranty on the repair or part involved.
Example: I had wheels replace due to clear coat failure. They were covered under warranty for 12 month even after the car was out of warranty.
Best to ask and if they say what ever is the concern is not covered you fix it yourself or take it to a shop that is able to deal with the problem.
As ChevyMGR has said the factory warrranty is the best if you do decide to extend it.
SindyDix
Aug 12, 2010 08:05 PM
plumb34
Apr 22, 2010 09:37 PM
solman98
Mar 2, 2009 07:47 PM
Goose
Jun 22, 2007 01:24 AM
Clarke33
Feb 22, 2006 09:40 AM
