Auto or 5spd? Which to get?
Old Jun 27, 2006 | 02:40 PM
  #51
EZ4U2CHere's Avatar
OK, I'm confused.... Someone please clear this up for me.
What's the difference in suspesion between the 1 & 2LT???
I thought it was that the 2LT had a bigger rear sway bar and stiffer springs.
Old Jun 27, 2006 | 02:41 PM
  #52
EZ4U2CHere's Avatar
BTW: I appreciate all the help!
Sorry about all the questions.
Old Jun 27, 2006 | 03:01 PM
  #53
captain howdy's Avatar
From the official Chevy site:
The tuned sport suspension, standard and available only on 2LT, includes variable-rate springs and gas-charged shocks with a 22mm stabilizer bar.
You also get 17" rims.
Old Jun 27, 2006 | 03:22 PM
  #54
EZ4U2CHere's Avatar
Isn't "variable-rate spring" another name for "progressive-rate spring"? If so, then I'm pretty sure goldlines are progressive.
So there's shocks on these cars and not struts. See, I'm still learning.
Old Jun 27, 2006 | 03:29 PM
  #55
No, they are two different styles of springs.
Old Jun 27, 2006 | 04:15 PM
  #56
dan-d's Avatar
Yes, variable rate and progressive rate means the same thing, the other choice is linear rate.
The HHR has shocks on the rear and struts on the front.
This from StangSuspension.com:
Progressive Rate vs. Linear Rate Springs - Many customers ask what the difference is between Progressive and Linear rate springs. A linear rate spring has a constant spring rating, no matter how much the spring is compressed, for example 600lb/in. This means that for every 600 pounds of pressure, there will be 1 inch of spring compression. A progressive rate spring will have a variable spring rate, for example 425-630lb/in. This means that it may take 425 pounds for 1 inch of compression, but as the spring compresses more it will rise to as much as 630 pounds of pressure. To put it simply, the spring "progressively" gets stiffer as it is compressed.
Old Jun 28, 2006 | 12:59 PM
  #57
vasyclone's Avatar
Originally Posted by dan-d
My personal preference is the manual. Both my wife and I just don't do automatics. I've been driving manuals so long the shifting just comes natural even in heavy traffic, we just don't think about it. I had to order mine to get the 2.4 with a manual tranny. I installed a short shifter made for a Cobalt in mine and it really shortened up the shift a bunch, I love it.
Been looking for you, Was the shifter being shorter the only difference? or was there anything else different about it ? Thinking about slipping one into my 2.4 5sp.
Old Jun 28, 2006 | 01:40 PM
  #58
dan-d's Avatar
The shifter is quite a bit shorter than stock and it was slightly extended below the pivot ball. Mine was for a Cobalt with the reverse lockout, but I just didn't use that part.
Old Jun 28, 2006 | 01:45 PM
  #59
JESSE's Avatar
I have the sport tuned suspension and 17" in wheels, but mine is a LT. Did I get lucky?
Old Jun 28, 2006 | 02:03 PM
  #60
It's impossible according to Chevy. The sport suspesion isn't even an option on the LS or 1LT. Maybe the dealer swapped 17" rims on yours?
From Chevys site:
The touring suspension, standard on LS and 1LT, includes variable-rate springs and a 19mm front stabilizer bar. It is not available on 2LT.
http://www.chevrolet.com/hhr/features/ and look at the Engine/Chassis tab.
