Automatic window switch question
Old Jul 10, 2008 | 09:12 AM
RkyMtnHHR's Avatar
The drivers side window has the ability to fully lower when you press the switch all the way. My question is would this work if I purchase a second switch and replace it for the passengers front window?
Old Jul 10, 2008 | 10:16 AM
richie6's Avatar
Thats a great question... I never thought about it!!
Someone must know!
Old Jul 10, 2008 | 10:21 AM
Cokeybill's Avatar
ChevyMgr would probably be your best bet...
Old Jul 10, 2008 | 10:44 AM
ZTony8's Avatar
The switch panel is one four button item.So it's a no go unless you want to tear one apart and see if the difference is internal and can be modified or it's in the BCM.
Old Jul 10, 2008 | 10:48 AM
Cajun's Avatar
I believe this was addressed before, and the verdict was a "no" ...
I hope I am wrong, I would like this also.
Cajun
Old Jul 10, 2008 | 11:13 AM
Canuck's Avatar
I would "suspect" this is not a switch feature but a relay that is activated with the switch. The switch themselves are probably the same, momentary contact, but when the relay is activated it holds and enable the circutry for the auto down.
Old Jul 10, 2008 | 01:57 PM
richie6's Avatar
Who is going to be first to try this out.. I don't think the relay would be to pricey...
Old Jul 10, 2008 | 02:08 PM
an08HHR's Avatar
When you go to gmpartsdirect.com they have a front right, front left, rear left and rear right at about $10 ea. I bet it can be done. Might have to change/add a wire or two
Here is a picture from rudeinc from a thread.
http://i88.photobucket.com/albums/k1...C/100_1851.jpg
Tyler Harvey
Apr 8, 2017 04:04 AM
jawzz1
Oct 28, 2008 08:05 AM
Stealth
Jan 31, 2008 10:49 PM
airbuff1
Mar 5, 2007 01:15 PM
