Battery location
Old Mar 12, 2007 | 09:14 AM
solman98's Avatar
Originally Posted by jx3
Good luck with that one!
I don't have that issue, mine dies, I just push start it....
Then drive to have new battery installed.
Old Mar 12, 2007 | 09:17 AM
Only time rear hatch became an issue for me was when the accuator failed.
Old Mar 12, 2007 | 10:25 AM
DreamHHR's Avatar
Having the battery in the rear is better for the car.
Well, it does help for the front / back weight balance, and as mentioned, keeps the battery out of the nasty environment (heat & corrosion wise).
I'm also not sure if I'm reading that it CAN be recharged from the terminal post under the hood? Can anyone confirm ?
I'm an engineer by profession, so I tend to try to anticipate what may or may not go wrong with any given design. Can't help it....
My comment about the main battery cable potentially wearing out it's insulation and shorting under vibrations is pure speculation on my part, but I've seen it happen elsewhere and would surely like to know what the HHR designers have done to prevent that. Again, this just stems from the fact that the cable is longer than usual, therefore more "exposed" to this problem.
Yves
Old Mar 12, 2007 | 12:33 PM
Snoopy's Avatar
DreamHHR....
can't tell you to what extent GM consider vibration....but I'm sure they did. To what degree is questionable.
I did a total custom El Camino about 20 years and moved the battery to an insulated box in the rear bed. Ran the cable along the frame and used black HD "zip-ties" to secure it. Never had a problem in about 15 years. The real issue is to assure the cable is stationary and secure just before connecting to the battery.
In any event, you may be a little over attentive
low_k3y
2.4L Performance Tech
7
Apr 19, 2015 07:34 AM
EasyRay
Aug 13, 2013 09:50 AM
87silver
Maintenance and Upkeep
15
Feb 7, 2011 09:40 PM
longhornss
Feb 27, 2009 01:15 PM
DWC
Jun 22, 2007 10:28 PM
