Best way to route/wire for rear Uber/Lyft light?
As per Donbrew's recommendation - something like this wired to the battery under the rear floor will work to give you the 5V needed for the USB connector. However you will need a switch to turn it off as I would think it draws power even when the car is turned off.
https://www.amazon.ca/Charger-Voltme...46518484&psc=1
Did the kit not also come with an installation guide?
You need to heed this: "However you will need a switch to turn it off as I would think it draws power even when the car is turned off." - IT being the USB charger. That would need to be double checked, else it will drain your battery.
congasfuse
10
Aug 11, 2011 10:25 PM
