Best way to route/wire for rear Uber/Lyft light?
Old Feb 4, 2019 | 03:34 PM
NevoidHyp's Avatar
Originally Posted by whopper
As per Donbrew's recommendation - something like this wired to the battery under the rear floor will work to give you the 5V needed for the USB connector. However you will need a switch to turn it off as I would think it draws power even when the car is turned off.
https://www.amazon.ca/Charger-Voltme...46518484&psc=1
Did the kit not also come with an installation guide?
THANKS, that's perfect. and the remote interacts with the inline RF receiver to turn it on and off. and no, no installation guide...plug (USB) n' play.
Old Feb 4, 2019 | 03:35 PM
NevoidHyp's Avatar
i already have the same sign on my windshield, and i've tested it behind the rear passenger window—waaaay bright enough.
Old Feb 4, 2019 | 03:36 PM
NevoidHyp's Avatar
thanks for your help y'all.
Old Feb 4, 2019 | 05:01 PM
You need to heed this: "However you will need a switch to turn it off as I would think it draws power even when the car is turned off." - IT being the USB charger. That would need to be double checked, else it will drain your battery.
hhrumadbruh
Mods - Interior
18
Jan 30, 2016 09:10 AM
nybble
Jun 17, 2013 06:47 AM
congasfuse
10
Aug 11, 2011 10:25 PM
johnbrum
Jan 10, 2007 10:34 AM
