Check Engine Light - Code P0128 - Will it pass Emissions?
Old Feb 23, 2020 | 08:25 AM
Radco's Avatar
Thumbs up
Originally Posted by Oldblue
Trust me, I learned the hard way, two Stant, one purchased , one warranty, one MotoRad , still had code P0128 after a few days to a week, then AC Delco, problem solved, and no problems since 2012 and a lot of miles , like 150,000 on Oldblue.
Very interesting ! GREAT to know, I will be EXTRA sure to get the AC Delco when the time comes ! Noting sucks more then doing the same job twice lol. Amazing how some parts are touchy with the brand ! Putting that AC Delco on my parts list
THANKs for the great advice everyone
Old Feb 23, 2020 | 12:01 PM
That’s an AC Delco 131-158 180 degrees thermostat, the professional series one is not compatible with the HHR’s time space continuum parameters in it’s computer programming
Old Feb 23, 2020 | 02:32 PM
syclone's Avatar
Smog Check - CK Eng Light On
I can only speak for CA - Light on - Easy - Will not pass test - Clearing the code won’t make it pass - Once code is cleared you need to drive to reset monitors - This could take as much as 50 miles / possibly more. If you clear the code and drive enough to reset monitors and go right to smog it should pass if the problem is the slow warm up. I learned this one the hard way. The ECM expects warm to operating temperature within an allotted timeframe - if this doesn’t happen the AC is disabled - temp gauge may go to zero and CEL comes on. Even a bad seal on a good thermostat will bypass enough coolant to slow warmup to the point of an ECM timeout and consequent CEL illumination. As mentioned the correct one time fix is using the correct OEM thermostat. I went nuts completely convinced I had an electrical issue before I figured this out. I have found generally speaking OEM parts seem to be the best.
Old Feb 23, 2020 | 04:21 PM
They were built that way. I had to replace the Stant fuel cap the PO had installed, it failed at 6 weeks old.
Old Feb 23, 2020 | 04:50 PM
As I said earlier; if you want to try to get by the inspection run the car up to temp then park it for a couple of hours then start it back up. This will start the coolant temp warmer so it will warm to 180F on time. OR, choose a nice warm day for the sames effect.
Old Feb 23, 2020 | 08:40 PM
  #26
I don't miss inspections or smog testing either.
Old Feb 24, 2020 | 12:22 AM
  #27
syclone's Avatar
U are very fortunate if you don't live in CA - mandatory emissions testing every 2 years + very high registration fees
Old Feb 24, 2020 | 08:13 AM
  #28
Radco's Avatar
No Smog testing in Maine either :) Had it in Ct. glad I am out of there lol Only state inspection here for $12.00 on my HHR but Free on the dealer where I purchased my truck :)
Old Feb 24, 2020 | 08:27 PM
  #29
Radco- didn't know that, cool.
I've lived in states that had both, in fact as a kid I used to do the vehicle mechanical inspections. And at one point I got pretty good at drawing inspection stickers.. LOL (just kidding cause that would be illegal).
That was 100 yrs ago tho. So I don't miss any of that.
Old Feb 24, 2020 | 10:45 PM
  #30
It is actually federally mandated by area. I live 1 mile south of the dividing line between Northern Va and Central Va; if I lived on the other side of the Rappahannock river I would have to get smog inspection.
Northern Va is the DC suburbs. Maybe it is by county, they keep threatening us if more people move in.
Diablo72
Jun 1, 2016 11:25 AM
jdevries
Jun 21, 2014 06:53 PM
goetylsd
May 11, 2010 10:32 PM
LONALA
Mar 4, 2010 11:05 PM
Geoff
Jan 21, 2010 05:23 AM
