Clicking Noise Coming From Driver's Side
Old Jun 5, 2006 | 11:09 PM
Navyflyer11's Avatar
The reason I ask about what happens after 55 is I am wondering if it is wind related.
Old Jun 5, 2006 | 11:41 PM
james5011's Avatar
I believe I have found the problem. Apparently where the running boards connect to the car around the front driver tire there was a bolt that was loose. Loose enough to give the plastic covering enough give to rattle. I just took it for a spin and apparently no more click, click, click. Nothing like a little brainstorming to get your brain thinking. I am going to post a picture for you guys real quick. Thanks.
Old Jun 5, 2006 | 11:44 PM
Tokyo's Avatar
Awesome! Glad you got it all figured out, and that there wasn't anything major wrong with the HHR. Nice work!
Old Jun 5, 2006 | 11:45 PM
james5011's Avatar
Picture of where problem was.
This is behind the drivers side front tire where the bolt was loose.
Old Jun 5, 2006 | 11:47 PM
james5011's Avatar
Thank you, thank you. I will be taking service appointments upon request. Just keep in a single file line. Payment is due when services are rendered. Ha, ha, ha!!
Thanks again for the help!
Old Jun 5, 2006 | 11:48 PM
BlackHHR's Avatar
Nice find. I had that same bolt come loose after I put mud flaps on. I just put some silicone on the end and screwed it back in.
Old Jun 5, 2006 | 11:53 PM
james5011's Avatar
Good idea, it looked as if it was just put in there and never tightened at all by whoever installed the boards. If it comes loose again I will use the silicone.
Old Jun 5, 2006 | 11:57 PM
SoCalHHR's Avatar
See that nasty gap between the running board and body? If you loosen that bolt up again then push "up" on the running boards while tightening it, you can get rid of it.
Hope it helps,
Old Jun 6, 2006 | 08:38 AM
galladanb's Avatar
James5011,
Thx for joining the forum!!! Welcome aboard! Your GOLDEN!
(we are Majestic amethyst!)
Gotta pitch the Biltmore thread and our car club at ya!
Biltmore at:
https://www.chevyhhr.net/forums/south-east-29/labor-day-biltmore-bash-go-2018/
And the car club at:
https://www.chevyhhr.net/forums/south-east-29/forming-hhr-car-club-nashville-area-1718/
First meeting tonight!
If you will send me your contact info, I can add you to our mailing list,
Also, check back often, as I will update as much as I can...
Old Jun 6, 2006 | 04:39 PM
PhxHHR's Avatar
It comes and goes. Very strange. I have had a bad CV joint and you can feel it when you turn. This is just me going down the road and get up some speed and click, click, click.
Maybe it's the playing card flapping against your spokes?
trucky
Mar 17, 2013 12:46 PM
mikiec
Jan 23, 2012 06:21 PM
Heavies
Mar 29, 2011 02:52 PM
JJ_
Aug 19, 2008 05:13 AM
hhrdad
Jan 29, 2008 02:44 PM
