Cobalt SS
Old May 7, 2013 | 03:28 PM
Cobalt SS
Was the Chevy Cobalt SS turbocharged? If so what years?
Thanks
Boydie
Old May 7, 2013 | 03:33 PM
07azhhr's Avatar
08 and up just like ours.
Old May 7, 2013 | 03:58 PM
American & Proud's Avatar
Rest In Peace
Some 08's were NA as it was a transition year from SC to Turbo's
Old May 7, 2013 | 04:32 PM
Tyler Harvey's Avatar
Old May 7, 2013 | 05:01 PM
Will a cobalt SS engine fit in an HHR without serious problems?
Boydie
Old May 7, 2013 | 05:12 PM
Rest In Peace
Boydie
Same Engines used in both.
Old May 7, 2013 | 07:18 PM
Supercharged Cobalts
I guess some 2006s had Superchargers. Does anyone know anything about them? And will the engin fit into an HHR?
Boydie
Old May 7, 2013 | 08:18 PM
Rest In Peace
Boydie
Again, Cobalts and HHR's used the Same engines. The SS's Both use the 2.0 ecotec.
The 08 "SS" used a 2.4 NA Ecotec because the Contract for the Eaton M-62 had Expired and GM went with a Turbo setup after that.
The 05 SS had a Supercharger as well.
If you want a Supercharger setup you can take the 2.0 SC setup and put it on a 2.2/2.4. Or you could swap the whole engine if you know what your doing.
Old May 7, 2013 | 11:58 PM
ThatChevy's Avatar
Here are two threads that I found discussing the Cobalt SS engine that might help.
https://www.chevyhhr.net/forums/2-2l-performance-tech-5/supercharged-cobalt-engine-hhr-24410/
https://www.chevyhhr.net/forums/2-4l-performance-tech-14/cobalt-ss-supercharger-hhr-2-4-a-26745/
Old May 8, 2013 | 12:15 AM
prod's Avatar
05-07 cobalt ss supercharged
08-10 cobalt ss turbocharged (same lnf as hhr ss)
as stated above there was also an ss package with the 2.4 that was neither turbo or sc
putting any of those engines in an hhr is possible, but probably not worth the trouble as you would probably also need to swap all the computers, wiring etc and get it to work.
there are supercharger and turbo kits available to buy that will install on a 2.2 or 2.4 hhr, easier than swapping the whole engine
if you are saying you have an engine from a 2006 supercharged cobalt, you can remove the supercharger specific parts and put your own kit together cheaper than buying an aftermarket kit. You need more than just the supercharger though.
