Code P0171
Old Mar 24, 2024 | 05:13 PM
Pollardwk's Avatar
Got busy with yard work and other things, so haven't had much time with the HHR. But I did ask the owner again and he assured me the donor engine is a 2009 and IT DOES HAVE VVT. I do not see any cracks in the exhaust flange or around it but I intend to change the gasket where the manifold mates with the exhaust flange. I also will replace the exhaust manifold gasket, since I did remove the manifold to get the engine in the vehicle. I just want to be sure there are no leaks there. As for the injectors, I found 2 from the donor engine not working. I connected power to each one and only 2 would click, to let me know they were working. And, since I am trying to help this elderly person, I am covering all bases. Since I did install 2008 injectors, I am removing them and putting in 2009. That may take care of the problem.
I looked for the paper tag on the head to check the id number, but it is gone. I will look at the other places mentioned to see if I can find numbers that I can check to verify the engine. I did not personally get the engine, so I am relying on someone else. My bad!!
Since I don't have any other codes other than the P0171, I hope that the new gaskets and the correct injectors will solve my problem.
Thanks again for all of the help!!
Old Mar 26, 2024 | 08:34 PM
mongo's Avatar
I think if the engine ever essploderates on my HHR, I'm just gonna plop it on an S10 chassis
Old Mar 27, 2024 | 07:59 AM
This is where the partial VIN is supposed to be. I never could find the one on the oil filter bowl (2) and the one on the end (1) is paper that washes off. GM claims they are all marked.
hefleymusic23
Aug 1, 2023 11:15 PM
Ritasmobile
Jul 3, 2023 05:00 PM
06REDSEDANDELIVERY
Apr 24, 2023 04:51 PM
Sale7
Dec 6, 2020 02:43 PM
Jim W
Oct 2, 2012 09:42 PM
