Control arm bushings
Old Feb 19, 2017 | 08:38 PM
I gave you the part numbers the rear bushings are the same for all years of HHR, they will fit!
Many parts aren't listed for the 2011's cause they're just lazy and don't care to confirm fitment!
Old Feb 20, 2017 | 12:19 AM
Updated the parts list:
Lower Control Arm Rebuild Parts
- Duralast Rear Bushing (autozone) P/N - FB782 (2.37" or 60.2mm outer diameter)
- MOOG "problem solver" Rear Bushing - K200792
- MOOG Ball Joint - K80567 (require drilling out old one and bolting this in - FE1/3 ONLY - does NOT fit FE5)
- MOOG front LCA bushings - K200361
Old Jul 7, 2017 | 09:25 AM
Apparently we need to update again
Moog has released bushings with the aluminum LCA
K201285
But the K200792 do fit and work fine and are now listed for the HHR,
Just not plated
http://www.moogparts.com/pdf/problem...failure_EN.pdf
Old Jul 12, 2017 | 02:24 AM
SwissHHR's Avatar
By default are our lower control arms steel or aluminium? Or does it depend on model year or type or ...?
Old Jul 12, 2017 | 06:29 AM
All years of HHR LS LT or SS are aluminum LCA's
Old Jul 12, 2017 | 09:18 AM
SwissHHR's Avatar
Could it make sense to replace the complete LCA? As seen here:
Federal-Mogul Motorparts
Would it include all the parts mentioned above by whopper?:
Is the part on the left hand side of the picture the rear bushing? If yes, it looks a bit different than K200792 to me.
Old Jul 12, 2017 | 09:27 AM
aradmahogany's Avatar
Just buy the complete MOOG unit and install it that way, that is what I did. Got them off AMAZON.
Just be sure to bring an impact gun, cheater bar, and patience; that rear bolt can be a pain coming out and going in. For me, it was the going in part.
Old Jul 12, 2017 | 10:03 AM
No, it does not include the problem solver rear bushing. Note that it states it is for the "value driven repair". It should be good for many miles.
Old Jul 12, 2017 | 10:18 AM
I use the OEM LCA , drill out the rivets and install the ball joint then press out the bushing and press in a Moog problem solver K200792 bushing, done!
guille2228
Feb 11, 2014 03:01 PM
hhrfreek
Nov 24, 2011 02:19 PM
bigw10921
Jul 17, 2010 10:35 AM
Goose
May 30, 2007 07:11 PM
