Daytime running lights.
Old Jun 24, 2018 | 12:36 PM
Silverfox's Avatar
Originally Posted by Cliffs51
An Fyi to people who don't like the "headlight" daytime running lights. There is a separate fuse for them in the fuse block and if you pull that fuse it will disable the drl's. That way you won't have to flip the "defeat" switch to turn them off.
Thanks for that. It has been on my mind anyway.
I just removed the fuse #31 and relay #28 .... DRL's
Auto headlights still operate.
I do not drive after dark very often so I figure I will not have to replace any front "PIA" bulbs with only 32000 miles on the car now.
I have a White HHR so it is more easily seen.
Silverfox
Old Jun 24, 2018 | 12:47 PM
Cliffs51's Avatar
Your welcome. My HHR is white also 😁
Old Jun 24, 2018 | 03:21 PM
Ok, pulling fuses and relays to defeat a safety issue is something we can not recommend nor condone.
If you are involved in an accident and your visibility to the other driver is deminished, and your are found at fault, be prepared for your insurance company to step aside and leave you holding the bag.
This thread is closed!
brazodoro
Apr 7, 2014 09:36 PM
ewmiles
Jul 16, 2011 12:12 AM
Sasksurfer
Apr 24, 2010 11:12 AM
Marzipan
Feb 24, 2008 11:35 PM
helhedded
Feb 22, 2007 09:43 AM
