Exhaust manifold….
Old Sep 10, 2024 | 08:22 AM
Unbolt the housing , you’ll need to drain the coolant first then remove the coolant temperature sensor.
The sensor is 19 mm the three bolts are 10mm
Old Sep 10, 2024 | 08:48 AM
Gearhead1's Avatar
Thanks. I had forgot they were that housing…..this is the bolt. .
Old Sep 12, 2024 | 08:40 AM
Gearhead1's Avatar
Fortunately I was able to get what was left of the exhaust stud drilled and out without draining the coolant and removing the housing with heater hose pipes or damaging the threads in the head
Old Sep 12, 2024 | 11:46 AM
Great job , now show the jig you made!
Old Sep 12, 2024 | 02:23 PM
Gearhead1's Avatar
Jig
2 drill bushings, both .376-.377 OD so press fit in plate. 1 with .125” ID and 1 with .250” ID
the end of drill bushings I turned down to .308 cause that seemed the fit in the counter bore of the head, but I suspect probably really 8mm or 5/16 one. That is what I was able to use to locate the jig so bushing was centered.
Old Sep 12, 2024 | 03:01 PM
  #26
Good job! Thanks for sharing!
Notagain
Aug 15, 2024 04:34 PM
Rocket Dawg
Maintenance and Upkeep
56
May 21, 2024 03:48 PM
hhrumadbruh
May 7, 2024 03:29 PM
Defective
May 28, 2018 05:28 PM
capp002
Mods - Engine/Exhaust
36
Oct 30, 2011 10:56 PM
