First Time HHR buyer - Needs Advise.
Old Feb 6, 2016 | 10:01 PM
Jase25's Avatar
Thank you all, delayed getting the car because tax refund got pushed back due to the IRS site crashing this past week for a couple days. Anyway will have cash in hand Tuesday and will be picking it up Wednesday if all goes well with the test drive. Getting excited. Thanks again for all the kind words and advise!
Sincerely,
Jase
If I get her I will be sure to post pictures.
BTW what is the Difference between the LS And LT....this Oneil Orange I'm about to get is an LT model.
Old Feb 6, 2016 | 10:03 PM
Jase25's Avatar
Originally Posted by aradmahogany
WOW ITS GREGGS TWIN. Gregg is my HHR. WELCOME.
first issue was the Camshaft Position actuator solenoids, then the butyl patch water leak issue. After that its been smooth sailing. Overall a generally worry free car in my opinion.
Love the blacked out rims and grill. Did it yourself? If so how??
Old Feb 7, 2016 | 07:34 AM
The LT model is the upscale model, in the glove box there should be a sticker look for 1LT or 2LT you'll find all the build codes there also
Old Feb 7, 2016 | 07:46 AM
Jase25's Avatar
Cool thank you will look for that. When we take it for a test drive.
Also I know on our PT after about 100k the timing belt needed to be changed ~ seems to be the mileage that they start to fail ~ are there any repairs or preventative maintence I should be thinking about?
Thanks again and any and all input is greatly appreciated.
Sincerely,
Jase
Old Feb 7, 2016 | 08:13 AM
Our Trucklets have a timing chain, have a listen for chain rattle at cold start up, ask for any records of any repairs.
At 10 years old it's gonna need something, but then again everything might have been addressed , things like worn strut bearing plates, lower control arm bushings , clunking from sway bar end links and or sway bar bushings.
Check for brake judder, the steering wheel might shake under braking, that can be a result of the rear drum brakes not adjusted correctly, or the LCA rear bushings are toast!
Post up your findings before you buy, some of these problems can help you lower the price!
If your mechanically inclined they aren't hard to repair!!!
Old Feb 7, 2016 | 08:15 AM
Jase25's Avatar
Fantastic. Thank you again!
Old Feb 10, 2016 | 03:56 AM
Jase25's Avatar
Going today to finally check everything out and if all goes well I'll be bringing her home. Wish me luck and I will keep you posted!
Take care - Jase
Old Feb 10, 2016 | 08:18 AM
Good Luck! The HHR will tell you if it likes you!
Old Feb 10, 2016 | 11:59 AM
aradmahogany's Avatar
Yes I found my Gregg huddled, scared, and lonely under a tree in the used lot of a Ford Dealership full of twigs, leaves, and ants. He is as happy as can be now and I am happy as well. Good luck with your purchase and should any issues arise they are usually mundane and easily reparable; This forum will be a lifesaver for the length of your ownership!
Old Oct 3, 2016 | 12:28 PM
oODeliveryManOo
Feb 7, 2016 10:06 AM
LA2112
May 4, 2013 08:37 PM
akfinest1
Jun 8, 2012 01:08 PM
Bssgrl
Apr 24, 2007 09:55 PM
