Get window to work
Old Jan 16, 2023 | 08:11 AM
Hhrpanel2not's Avatar
Get window to work
I have a 2010 hhr panel ls that I put rear doors with windows for my dog. I would like to know if anyone can tell me what I need to do to get the windows to operate. Their is a switch on the door for the window and im fine having to use that switch if it's the only option
Old Jan 16, 2023 | 08:27 AM
greg8453's Avatar
Are they connected correctly?
Old Jan 16, 2023 | 09:27 AM
There is no harness for windows in the rear "cargo access" doors. The only way I can see is to find 12 V somewhere. How did you handle the door locks?
If there are Dark Green wires in the door harness one would be always hot 12v from the 30A underhood fuse #36. The switch supplies ground. Since the switch is really a sensor with multiple in and outs, I would probably use an after market window (actual) switch.
The Panel has 2 relay blocks that is activated by the switches on the waterfall. It is very complicated. One is under the hood and I think the other is behind the R taillight access panel.
Her is a pdf of the power widow circuit on non-Panel
power windows.pdf
Here is the door lock schematic
paneldoor.pdf
Rocket Surgeon!
Nov 13, 2022 08:16 AM
rickbz28
Dec 4, 2019 03:54 PM
Tanna Bowen
Apr 9, 2016 06:45 PM
jwjones
Nov 19, 2013 04:16 PM
emstess
Apr 19, 2010 03:25 PM
