Headlight replacement
Old Nov 21, 2019 | 12:34 PM
Flyinmech's Avatar
Thanks to everyone
I got the bulb done, did not like not seeing anything. The guy who designed this should be shot. I can not believe that for something like changing a headlight bulb, they couldn’t come up with something better. If I had a shop and lift I would create an access hold, install a plug and seal with silicone.
Old Nov 21, 2019 | 03:02 PM
Only 3 that NEED to be removed, depend on your pain tolerance level. If you need to see what you are doing and don't want your forearm all scratched up you can remove the entire fender liner, or the bumper cover and light housing.
My Toyota Tacoma was almost as much trouble except that there was nothing to remove to make access easier. All the "stuff" under the hood was obviously installed after the bulbs.
Oddly enough you are not the first to complain about it. We get a chuckle out of it, now. "Isn't the newby cute?"
Old Nov 21, 2019 | 03:41 PM
Dan’s F250, required four or five bolts to be removed and then wrestle the headlights out of their places
Old Nov 21, 2019 | 08:47 PM
Many other rides set-ups that are 'hard" to replace bulbs.
Ours is easy imo in comparison..
Ron S
Jan 14, 2021 08:11 PM
Cliffs51
Maintenance and Upkeep
12
Jan 23, 2019 10:12 AM
rywegh
Jan 4, 2017 04:30 PM
Juan
Mods - Exterior
Nov 14, 2014 08:29 PM
dseago
Feb 10, 2013 01:39 PM
