Heater
Heater
i have a question about my heater when i turn the dial to where it blows either defrost and feet or defrost only it sounds like the ac compressor kicks on, is it supposed to do that?
I believe that when you turn on defrost, the air compressor is supposed kick on. I have had others cars set up that way, and I think the HHR is also. Someone correct me if I'm wrong, but I think it has to do with the defrosts ability to clear the inside of the windshield.
It's normal. Hope someone else can chime in if I'm wrong or missing something here...I think the idea behind the AC compressor coming on during the defrost/defog mode, is to dehumidify the air (remove the moisture from the air) circulating through the cabin. This especially helps when you're trying to remove the fog from the windshield.
This is a normal condition on vehicles equipped with air conditioning. The a/c turns on when in defrost mode in winter because it dries the air and removes the humidity making defrosting more effective. Hope this helps!
Does this mean that even in cold conditions - like -20 C - the a/c engages and attempts to dry outdoor air which is already very dry?
Or does the a/c only attempt to dry recirculated air? This makes more sense to me.
-(Defog): This mode directs approximately half of
the air to the windshield and the side window outlets and
half to the floor outlets. When you select this mode
the system runs the air conditioning compressor.
To defog the windows faster, turn the temperature
control knob clockwise to the warmest setting.
Recirculation mode is not available in defog mode.
0(Defrost): This mode directs most of the air to the
windshield, with some air directed to the side window
outlets and the floor outlets. When you select this mode
To defrost the windows faster, turn the temperature
@(Recirculate): Press this button to prevent outside
air and odors from entering your vehicle or to help heat or
cool the air inside your vehicle more quickly. An indicator
light above the symbol will come on in this mode. The air
conditioning compressor also comes on. This mode is not
available for floor, defog and defrost modes. When the
recirculation button is pressed, the recirculation indicator
light will flash five times and outside air will be delivered.
Operation in this mode during periods of high humidity
and cool outside temperatures may result in increased
window fogging. If window fogging is experienced, select
the defrost mode.
the defrost mode.
