Help...
Old Feb 26, 2023 | 12:44 PM
angiekay's Avatar
Ok I cant drive it so can i buy a code checker?
Old Feb 26, 2023 | 12:46 PM
angiekay's Avatar
Check engine light has bn on for about a year. As has my passenger airbag light-assumed that was the reason it came on
Old Feb 26, 2023 | 01:23 PM
Did the person that regularly services your car mention how dangerous it is to ignore warnings on the dashboard?
At this point it is pretty useless to check codes. It needs to be taken to someone that can fix whatever is wrong; I would not be shocked if the timing chain broke and caused major damage.
Old Feb 26, 2023 | 01:54 PM
Seems to me, that’s a strong possibility, or the battery died!
Old Feb 26, 2023 | 03:07 PM
I'm with donbrew. Sounds like no compression, timing chain issue. Hopefully the engine isn't destroyed, Don't crank it anymore until the timing components are inspected. You can do this yourself by simply removing the valve cover.
Old Feb 26, 2023 | 05:31 PM
PulpFriction's Avatar
Don'r drive it, don't try to start it, don't even let a mechanic try to start it until it's been established the the timing chain is OK.
Tow it to a competent shop that has experience doing Ecotec timing chains. If you want to do something in the meantime, get the codes read and write them down (the numbers, not the descriptions.) All of them.
Old Mar 2, 2023 | 02:26 PM
angiekay's Avatar
Sorry for not answering any of the post. I've bn working major overtime! So im going to YouTube the timing chain. i can at least learn where it is evn if I cant fix it myself. I would like to eliminate possibilities before I take it somewhere. I appreciate the replies & advice -I'll keep u posted
Old Mar 2, 2023 | 02:36 PM
https://www.chevyhhr.net/forums/how-...in-kits-60394/
Loads of information in this thread and
http://www.ddmworks.com/assets/image...uild%20Kit.pdf
Old Mar 2, 2023 | 02:42 PM
greg8453's Avatar
If you don't know where your timing chain is you will not want to attempt this job.
Old Mar 2, 2023 | 06:10 PM
angiekay's Avatar
Most certainly will not attempt! Watch the video- too much for me to remove!! Ok so playing this process of elimination Ive got going on... Is there any way of ruling out the timing chain without inspecting it? In my mind-correct me if im wrong-I can rule out any part of the starter, like the bendex (sp)? Bc of How it died on me on the interstate...lost power Then died. And not the alternator bc my battery is still capable of cranking & not drained... Am i on the right track?
